Posted by JRSutton on December 04, 2011 at 18:10:15 from (75.130.109.233):
In Reply to: M still not running posted by Todd Heck on December 04, 2011 at 14:02:57:
Have you tried turning the gas off yet?
Sorry to keep pressing the point, but I've re-read a few times and see no mention of you trying it.
(although with my A.D.D I often miss details people type, sorry if that's true here)
Just shut the gas off and keep it off. Keep cranking on and off for a good 5 minutes. While the gas gets used up, you'll eventually pass a point where the mixture is just right and it should at least fire a few times.
If nothing - drain what's left in the bowl - pull and clean the plugs.
Try starting it with everything dry using starter fluid only - no gas.
(I think you said you did this without the carb in place, but that might be a little too wide open -- and definitely use starter fluid, or carb cleaner if you don't have the fluid. Spraying gas alone probably isn't enough)
If it goes with the starting fluid, you can be fairly certain it's a carb issue.
If not it's probably a timing/spark issue.
If, like you said, you're getting a 1/4" blue spark, that's good, so most likely a timing issue.
A timing light should show any problems, even while just cranking the engine.
If you don't have a tdc mark on the crank pulley, just put one there yourself.
This post was edited by JRSutton at 18:19:09 12/04/11.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
