Posted by Berghandler on December 05, 2011 at 11:24:40 from (207.67.93.212):
I have restored a 1947 w/regulator 6 Volt H. I did nothing to the engine, govenor, carb or manifold because it was running faily good prior to teardown. I cleaned carb by putting entire carb in carb cleaner. I also replaced all plugs, plug wires, points and wiring. I now try and start and it starts O.K. but at a high RPM and I can"t throttle down at all. I have rechecked the govenor connection where the keyed shaft goes into the carb to fit with the mating part that controls the manitfold butterfly and It"s O.K. I haven"t done any adjusting to carb because it was O.K. before teardown, but the sediment bowl was very dirty and I beleive that the carb had to be sucking fowl gas. It now is all clean but start"s off at high RPM. I am going to check the throttle linkage yet because that"s the only other thing I had diassembled but I think it"s also O.K. Any ideas why??
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
