Re: High RPM at start on H
Posted by rustyfarmall on December 05, 2011 at 16:34:26 from (216.248.71.224):
In Reply to: High RPM at start on H posted by Frank Caldwell on December 05, 2011 at 11:24:40:
That governor tab can easily end up right in the slot where it should be, or just above the slot, or just below the slot. Moving the throttle linkage with the tab in either of those 3 places WILL cause the throttle plate to open or close, but if that governor tab actually ended up BELOW the slot, the carburetor is then free to go wide open when you start the engine.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
