Re: Ok, I think I might have a good question... (H follow-up
Posted by Tom Fleming on December 05, 2011 at 17:57:55 from (206.193.250.146):
In Reply to: Ok, I think I might have a good question... (H follow-up) posted by Crazy Red Power in SE-WI on December 05, 2011 at 17:35:45:
Well, with zero compression, my opinion is that the valves are hanging. Unless each piston has a hole in it. even sticky rings will provide a little compression.
So, check your valves to see if they have full travel and are closing all the way. Use a small brass hammer or similar. On each valve that has a loose push rod (ie. valve is closed), tap the valve and see if it moves. It should "snap" back with a distinct sound as it seats. If the valves don't snap back or make a sound when seating, you have valve issues. Could be corroded stems or rusted seats. Either will not seat and seal.
