Re: Wiring diagram for 340 Indernational 12 volt conversion
Posted by Janicholson on December 07, 2011 at 13:04:00 from (199.17.6.80):
In Reply to: Re: Wiring diagram for 340 Indernational 12 volt conversion posted by TomNeb on December 06, 2011 at 18:16:22:
The regulator and diode bridge in the alternator must be changed to match the ground. There is no way to change it other than that. Almost all alternators in use today Delco 10SI and others are all pos ground. Easier to replace than modify. Someone on here will like it if offered. Jim
