Re: Wiring diagram for 340 Indernational 12 volt conversion
Posted by TomNeb on December 06, 2011 at 18:16:22 from (174.253.136.130):
In Reply to: Re: Wiring diagram for 340 Indernational 12 volt conversion posted by Janicholson on December 06, 2011 at 09:22:49:
I have an IH 300 and it has been converted to 12 volt and has an alternator and 12 volt coil but still has a positive ground. I would like to switch to a negative ground and double check if the conversion was wired correctly. Does anyone know what needs to be done to switch to a negative ground and does anyone have a schematic to see if the wiring was done properly?
