Posted by Ben Henke on December 07, 2011 at 19:59:45 from (166.182.3.107):
I am working on 986 clutch.Here s the issue.I installed a new disc and pressure plate.Set the clutch adjustments to service manual specs. After 10 Hours you can t shift it without grinding high low or rev. Adjusted linkage 4 differnt ways, nothing helps.First clutch/Allied Installed second clutch. HY-Cap Same thing.You can only shift without grinding after you stop and first 2-3 shifts upon start up. Has anyone run into this before? The input shaft splines are worn. Could this cause the disc to hang and drag? Thanks Ben
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
