Re: Splitting an A
Posted by Janicholson on December 11, 2011 at 14:53:39 from (199.17.6.80):
In Reply to: Splitting an A posted by charlie M on December 11, 2011 at 11:11:52:
In my opinion you need the Engine off first to do the rear main seal, (and replace all worn clutch parts and T/O bearing while in there.
Then split the front off of the tranny to fix that seal while it is still split at the clutch.
Then put that system back together , then thew engine. Be careful, the front end can tip easily. Block everything well, and hold weight so it cannot tip. Jim
