Re: Splitting an A
Posted by CNKS on December 11, 2011 at 16:59:43 from (216.144.104.128):
In Reply to: Splitting an A posted by charlie M on December 11, 2011 at 11:11:52:
I took off the engine, then removed the middle part. You can then fix the transmission, put the middle part back on and manage the drive shaft and clutch shafts without a problem. When you remove the middle part be sure you have the rear end blocked up.
