Re: 1944 H, factory error????
Posted by rustyfarmall on December 12, 2011 at 14:09:39 from (216.248.71.224):
In Reply to: 1944 H, factory error???? posted by IAtractorKid on December 12, 2011 at 12:25:45:
The Hs and Ms were shipped from the factory with the cast wheels "dished in" to make the tractor as narrow as possible in order to fit more of them on the rail car. The dealer then simply swapped the wheel/tire assembly from one side of the tractor to the other, to achieve the "dished out" stance, which was required for MOST rowcrop operations. Simply swapping the wheels from one side to the other DID leave the non-removable lugs on the outside, and the removable lugs on the inside, which makes removing the rim/tire assembly nearly impossible. The answer is to get busy and completely remove all the lugs, bolts, and nuts, and then reassemble it the way YOU want it.
