Re: Farmall 826 injection pump
Posted by Rich in IN on December 14, 2011 at 05:22:13 from (75.146.127.110):
In Reply to: Farmall 826 injection pump posted by jpavao1066 on December 13, 2011 at 14:37:12:
Make sure lower control lever always contacts front screw after starting. Keep water out of fuel, Bosch VA pumps will last a long time, but many hard parts are no longer available. Lever can be jumped one spline and screw reset on dyno, two splines is usually too much on test stand. If you go too far, engine will stop anyway.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
