Re: Farmall 826 injection pump
Posted by jpavao1066 on December 14, 2011 at 08:30:26 from (65.110.131.85):
In Reply to: Re: Farmall 826 injection pump posted by Rich in IN on December 14, 2011 at 05:22:13:
So to jump a spline, would i just remove the spring on the linkage, pull the linkage off and jump it back one spline? Im just making sure its as easy as i thought. Unfortunately i cant go look at it now because i am out of state finishing my semester at college, so im picturing all of this from memory.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
