Posted by rustyfarmall on December 15, 2011 at 14:13:38 from (216.248.71.224):
In Reply to: sticking clutch posted by D Slater on December 15, 2011 at 11:48:33:
There is an access hole in the housing directly below the flywheel to give access to the grease zerk for greasing that pilot bearing, and if the engine rear oil seal WAS leaking, the oil SHOULD just drip out of that access hole. I suppose if that hole was plugged up, the oil would accumulate and eventually be enough to get on the clutch plate, and yes, that would cause some issues, but there are so many other places where that oil could leak out that it would not be very likely it could ever get on the clutch.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
