sticking clutch
Posted by sven on December 15, 2011 at 11:48:33 from (65.127.84.74):
I have a famall h with a clutch that sometimes seems to stick to either the flywheel or the pressure plate. When you push in the clutch, especially after pulling hard, the tractor will continue to move. Usually about three seconds later it disengages all at once as if the friction disk popped away from the flywheel. If I tapp the brakes right after pusing in the clutch it will disengage too. It does not happen all the time but it is very concerning when it does happen. What could be causing this?
