Re: sticking clutch
Posted by glennster on December 15, 2011 at 14:42:09 from (76.223.247.78):
In Reply to: sticking clutch posted by sven on December 15, 2011 at 11:48:33:
if you want to rty and grease the pilot bearing like rusty said, look at your timing marks on the crankshaft by the fan belt. there will be two right together, and one all by itself a ways around the pulley. line the single mark up with the timing pointer, then peek up in the hole below the flywheel. you should see the zerk right there. 2 to 3 pumps max from a grease gun should so it. no more than that.
