Farmall A Battery Connections
Posted by Douglas Moser on December 16, 2011 at 10:59:30 from (173.67.148.205):
I've got a 1946 Farmall A that suddenly does not start. I'm not surprised since it does not get much use other than a few weekends here and there. I removed the battery and bench charged it for several days. Problem is, when I went to put it back in, I forgot whether it is positive or negative ground. I have not been able to find my schematics, so I'm wondering if any of you folks might be able to let me know. Thanks in advance for any help! Doug
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
