Re: Farmall A Battery Connections
Posted by old on December 16, 2011 at 12:04:43 from (209.86.226.34):
In Reply to: Farmall A Battery Connections posted by Douglas Moser on December 16, 2011 at 10:59:30:
From the factory it would have be + ground and 6 volts but you have not given us enough info for use to be able to help you help your self. If still 6 volts and has a generator then it would be + ground but if 12 volts and has an alternator then it stands a 99% chance it is - ground and if it has an alternator and you hook it up back wards you will smoke test the alternator the moment you hook it up
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
