Farmall Tractors Discussion Board
Re: Re: 2 farmall questions
Posted by Stan(VA). on January 08, 1999 at 04:55:57:
In Reply to: Re: 2 farmall questions posted by Phil Auten on January 08, 1999 at 04:42:42:
The SM was built in two models or series. The early ones had the old style belly pump hydraulics just like the straight M. The late ones offered a live hydraulics option with the pump between the distributor and the block, and rubber lines connection the the reservoir under the fuel tank. The battery on these models was moved under the seat to make room for the reservoir. The metal hydraulic lines were first used on the 400 series.
But back to your question, the SM can also be identified by disc brakes instead of band brakes. The engine was a 264 instead of a 248 inch model of the straight M.
Stan(VA).
Post a Followup
: Re: Re: Re: 2 farmall questions
