Re: Smoke from mainfold bolt area
Posted by ltf in nc on September 03, 2000 at 17:28:36 from (206.228.214.116):
In Reply to: Smoke from mainfold bolt area posted by BTD on September 03, 2000 at 16:28:39:
The smoke that you saw most likely came from oil running down the exhaust valve stem and then was blown out with the exhaust into the manifold where it seeped out the bolt. The valve guide seals (assuming your tractor has seals) are bad or the valve guides themselves are worn. This is not a problem to fret over.
Post A Followup
: Re: Re: Smoke from mainfold bolt area
