Farmall A Manual Mid Lift Value
Posted by Drew W. on December 19, 2011 at 21:04:09 from (69.132.116.79):
I bought a "45 Farmall A that came with a manual lift mounted between the rear bullgear housings. It has a handle that sits between the right tire and fender. It doesn"t have any attachments with it that directly attach to the lift. There is also a spring that goes from the lift under the gas tank to the mid-lift on the left side of the transmission. I will attach what pictures I have of it assembled. Everything is now in my basement in piles.
I"m thinking of selling the mid lift since I have no use for it. It"s 100% complete with an even coat of surface rust. I have everything broken free and moving. What would something like this be worth?
Thanks,
Drew
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
