Re: Farmall A Manual Mid Lift Value
Posted by gene bender on December 20, 2011 at 08:31:26 from (67.55.227.100):
In Reply to: Farmall A Manual Mid Lift Value posted by Drew W. on December 19, 2011 at 21:04:09:
Looking at the pics of implements the lever between the tire and fender is the lift lever for the A-147 Disc Plow.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
