Re: break-away coupler on a Farmall 350
Posted by D Slater on December 21, 2011 at 15:12:05 from (184.15.30.71):
In Reply to: break-away coupler on a Farmall 350 posted by DonO-MN on December 21, 2011 at 08:25:21:
I remember a extra block bolted to the bottom of the right side hydraulic outlet block. Steel lines run from it down the right side under the deck lid overhang. Rubber hose was made to the lines near the end and went to the coupling that was mounted above the pto to a bent bar that attached to the top cover.
