Re: H regulator wiring
Posted by LonM on December 21, 2011 at 18:23:56 from (69.165.30.204):
In Reply to: Re: H regulator wiring posted by Janicholson on December 21, 2011 at 18:10:08:
Thanks Jim- so to clarify, the wire I have from the light box that is currently unhooked should be connected the the L terminal on VR? And the way the rest is connected would be Bat to Ammeter, Gen Field to VR Field, and Gen Arm to bottom terminal on VR?
