Re: 656 ignition problem cured
Posted by rustyfarmall on December 23, 2011 at 12:47:29 from (216.248.71.224):
In Reply to: 656 ignition problem cured posted by tntleake on December 22, 2011 at 18:54:49:
Here is the link to the Pertronix manual.
http://www.pertronix.com/support/manuals/pdf/ignitor12vneg.pdf
From what I can gather, the external ballast resistor is to be used, or not used. I assume it depends on whether the coil being used is a 6 volt coil, which WOULD require the resistor, a 12 volt coil that is internally resisted which would NOT require the resistor, or a simple 12 volt coil which DOES require the external resistor. If a ballast resistor IS used, the wire feeding the electronic unit SHOULD NOT go through the resistor, but the wire feeding the ignition coil DOES go through the resistor.
