656 ignition problem cured
Posted by Fixerupper on December 22, 2011 at 18:54:49 from (199.120.105.202):
A couple days ago I posted a few questions about the arrangement of the ignition system on a 656. It acted like it wasn't getting strong enough spark to start while cranking and I questioned the resistor arrangement. This thing has electronic ignition.
I talked to the shop foreman at a CIH dealer and he told me the resistor should NOT be connected when an electronic ignition is installed. I've never had any experience with add-on electronic ignition so I was groping in the dark for an answer. Ten minutes with two wrenches,a screw driver and cold fingers and I had the resistor disconnected and bypassed. Hit the starter and after three revolutions it started right up. Hooray! The owner said he didn't use this tractor last winter because it was such a pain to start. He might not use it this winter either, but at least now it's ready if needed. Jim
