Re: farmall 450 to MTA
Posted by D Slater on December 25, 2011 at 16:35:44 from (184.15.30.71):
In Reply to: Re: farmall 450 to MTA posted by 460anger on December 25, 2011 at 16:18:19:
MD should screw in since its the same as a non power steering 450 and there's no difference in the bolster or circle gear for both steering types. But it will be to long with the short frame rails you need a M gas one. Most center steering shaft support brackets are worn so much it doesn't matter, but a M gas and a SMTA is a little different. Because the angle of steering shaft and extra lenght make it higher when it gets back there. M, SM steering support works for the short rails if the right length was removed.
