I tested a brand new 6 volt universal coil with my ohmmeter, and also tested a brand new 12 volt coil that does not need the external resistor. Both coils had exactly zero ohms of resistance across the positive and negative terminals, and when tested from the positive, OR the negative terminal to the tower, the ohmmeter read exactly 9 ohms of resistance on BOTH coils. Granted, I was using a cheapy ohmmeter which most likely is NOT 100% accurate, but it IS consistent.
I do not have a 12 volt coil that REQUIRES an external resistor, so I could not do that test.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
