Re: IH 674 PTO problems
Posted by Mudcat49 on September 05, 2000 at 06:18:30 from (209.26.211.30):
In Reply to: IH 674 PTO problems posted by Mitch on September 05, 2000 at 03:56:34:
Mitch:
I think that tractor has the standered IHC PTO on it. If so all you have to do is disconnect the linkage on it and take four bolts out to get it off. I always try to get the tractor pointing downhill so the hy-tran doesn't run out all over the place. ( I hafta use a ditch here in south Fl., no hills) Also you need to take the top link off and then remove it's bracket to get to the drive shaft, for removal and to put it back in, BE CAREFUL DON'T MESS UP THE PICK-UP TUBE ON THE PTO !!!!!
Post A Followup
: Re: Re: IH 674 PTO problems
