The TA was meant to be used only when encountering a particularly tough spot in the field. A spot where you would need to downshift if you didn't have the TA. If you feel the need to use the TA on the low side for most of the trip across the field, then you are abusing it. Choose a gear that allows you to use the TA on the high side most of the time, and pull that lever back when the going gets tough, and just as soon as you get through the tough spot, throw the lever forward again. The TA was never intended to be used as a device to slow you down, and should not be used in that manner.
Today's Featured Article - Storing Your Tractor - by Staff. If your tractor is going to be stored for any length of time, a few precautionary measures are helpful in preserving various parts, also in avoiding future difficulty. Store tractor under cover. If impossible to place tractor under cover, be sure to cover air stack and exhaust pipe. Drain radiator and engine block. To avoid gum content collections, drain both fuel tanks and carburetor. Leave radiator and fuel caps slightly loose to protect gaskets. Block tractor up to remove weight from tires and to keep tires from contact with moist floor.
... [Read Article]
Latest Ad:
[More Ads]
