Re: TA To use or Not to use????
Posted by The Dukester on December 29, 2011 at 19:58:31 from (4.229.144.96):
In Reply to: Re: TA To use or Not to use???? posted by rustyfarmall on December 29, 2011 at 06:06:54:
TA's were meant to be used for changing the tractor's traveling speed to a lower rate, but not to BRAKE the tractor down to a slower speed. You pull the TA lever to the dog/catch position deliberately and briskly to slow the tractor's speed when it is pulling, not coasting, and you release the dog/catch and let the lever go forward freely to resume the speed to the higher rate. Simple as that....there's many reasons to reduce the speed of the tractor sometimes...I can't tell you how many situations you may encounter to need to reduce the tractor's speed.....and get the additional pulling power the tractor will have at the reduced speed, but that's what it was mainly designed to do. Shift down without having to use the clutch at all...and back up when you can resume speed...really neat!
