Sending unit is right on back side of mcv which is on left side of tractor on clutch housing. Just unhook the wire, if lamp goes out you know wire from lamp to sender is ok. If lamp stays lit you have a ground on wire between lamp and sender. After that it could be sender or actual low pressure. It would need to be checked with qauge. It is trans lube pressure and normally about 18 to 20 psi. It is very possible for all hydraulics to work and still have no or low lube pressure and that is not good.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
