M Governor Adjustment
Posted by Rod in MN on January 01, 2012 at 12:17:31 from (66.242.67.252):
Hi Guy"s Happy Year wind gust up to 40MPH here
I"m working no dad"s M removed carb and cleaned install new kit but the needle seat hole is bigger then the old one. Used old seat
On the M it has a M&W throttle lever handle took cover off side of gov housing i can adj the low speed screw to stop with no spring tension go to high side stop screw can not hit the stop it"s 1/2" short a lot of spring tensio
