Re: Farmall Generator Cut Out
Posted by 38F-20 on January 01, 2012 at 14:17:18 from (50.82.60.201):
In Reply to: Farmall Generator Cut Out posted by 38F-20 on December 31, 2011 at 17:52:14:
Thank you for all of your input. I bought a 6-volt cut out a few years ago, and didn't know if it would work on my system now. So basically, I should either use a 12-volt cut out or a diode to be sure that the battery is disconnected from the generator.
I was going to use an original 4 position switch off of a Farmall H to use the low charging setting all the time. Is there still much risk of overcharging the battery without a regulator by using this method?
