Re: Farmall Generator Cut Out
Posted by Janicholson on January 01, 2012 at 14:43:13 from (96.24.99.126):
In Reply to: Re: Farmall Generator Cut Out posted by 38F-20 on January 01, 2012 at 14:17:18:
The low charge position charges at about 4 to 5 amps. (if the third brush is adjusted correctly) thus it absorbs ignition current, and a little for the battery. The High charge position is to establish a recharge of the batery and will need to be turned to L after about 15 minutes of work. A skill of the operator is to know when to do so. Jim
