Posted by Janicholson on January 02, 2012 at 08:09:59 from (199.17.6.31):
In Reply to: IH 560 backfire miss posted by Craigswanson on January 02, 2012 at 06:14:21:
Possible bad plug wires. If wire is inside, (wound magnetic suppression, or solid stranded wire, the issue is conductivity. yes or no. If carbon suppression wires, 5000 to 7000 ohms per foot of length. The distributor cam bushing could also be causing issues with timing No more than .001" looseness. The final component to check is condensation in the distributor cap causing mis directed spark. Use a blow drier, then silicone spray. If that still is no fix, water in the fuel could make that symptom. (not likely if you are using 10% Ethanol fuel. Jim
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
