Re: Uses for belly pump?
Posted by Wardner on January 03, 2012 at 11:36:18 from (4.154.232.134):
In Reply to: Uses for belly pump? posted by MeanGene1 on January 03, 2012 at 10:48:41:
If you use a nomograph provided in some hydraulic catalogs and literature, you will see that 1000 psi at 1 gpm is close to 1 hp. A continuous high pressure load on a later M Liftall would be about 10 hp. You will probably run into overheat problems if you don't plumb in some return line cooling hardware.
