Uses for belly pump?
Posted by MeanGene1 on January 03, 2012 at 10:48:41 from (71.141.251.211):
Can a belly pump from a parted M be used for regular pump use, such as running a log splitter etc? Can it be overdriven, pressure raised, etc. enough to be worthwhile? How much actual hp does it take to drive one, and if it could be turned up, then how much hp? Seems a shame to waste a pump if it's usable for other things, and I have a splitter that was previously run off loader hydraulics, has about a 4x24 cylinder
Thanks in advance
