Re: Uses for belly pump?
Posted by MeanGene1 on January 03, 2012 at 12:05:30 from (71.141.251.211):
In Reply to: Uses for belly pump? posted by MeanGene1 on January 03, 2012 at 10:48:41:
I hoped you would respond, as you are the resident "McGuyver" with these tractors LOL. So do you think it's feasible to do this, and would it necessary/feasible/possible to raise output by overdriving, and can the pressure be also increased to efficiently run something like a splitter, and if so, how? I don't recall ever seeing where anyone had used a salvaged belly pump as a standalone pump? I would have two to chose from, a '50 M and a '53 Stage 1 SM- sounds like they are different pumps, with the later pump being better/ more output and/or pressure?
Thanks again
