Re: Uses for belly pump?
Posted by Nebraska Cowman on January 03, 2012 at 15:57:48 from (66.252.115.26):
In Reply to: Uses for belly pump? posted by MeanGene1 on January 03, 2012 at 10:48:41:
When I worked for a machine dealer 40 years ago he had a New Idea loader on an old M with overdrive. When we wanted to lift something heavy we engaged the overdrive. It did help.
