Re: M starter problem
Posted by Andy Martin on September 05, 2000 at 21:27:45 from (38.31.74.139):
In Reply to: M starter problem posted by todd on September 05, 2000 at 21:03:32:
The bendix is hung up in the flywheel.
Make sure the switch is off and put the tractor in 5th. Rock it by pushing on a rear tire until you see the fan turn a little. The starter will be free.
I have a tractor I have been putting up with this on for years because it is only a seldom occurance.
On others it got frequent and I fixed the problem by replacing the starter drive.
You could have a bad ring gear compounding the problem, but a new starter drive is the first fix.
Post A Followup
: Re: Re: M starter problem
