Re: Re: M starter problem
Posted by john d on September 05, 2000 at 21:39:14 from (205.188.197.164):
In Reply to: Re: M starter problem posted by Andy Martin on September 05, 2000 at 21:27:45:
If rocking the tractor BACKWARDS in 5th doesn't work, or the thing is parked where you can't do that, loosen the mounting bolts on the starter and shake it a little. The drive will retract. Then tighten it and start it! Whatever you do, don't PULL the tractor to start it with the starter jammed!
Post A Followup
: Re: Re: Re: M starter problem
