Re: Need help identifying a rod (pic)
Posted by 36F30 on January 04, 2012 at 18:22:54 from (75.170.151.214):
In Reply to: Need help identifying a rod (pic) posted by Mike1972chev on January 04, 2012 at 17:41:06:
Farmall-h said: (quoted from post at 18:49:19 01/04/12) When I bought my H, it came with the very same set up only difference is the shutters were on it! After I freed the control rod up, it works like a gem! These were an attachment that could be special ordered and most commonly used on tractors that would plow snow in colder regions. It could be closed somewhat to keep warm air in and recirculating, and on a warm day, opened completely to allow regular air flow for engine cooling purposes.
If you do decide to free the rod up, make sure you apply anti-sneeze to the threads on the adjustment lever. You will never have a problem with it again!
-Cole
Radiator shutters were for kerosene burning tractors started on gas, they were required to bring engine temperatures up to temps high enough to vaporize heavy kerosene fuel without stalling and were adjusted to keep the temperature in operating range. Nothing to do with plowing snow, just required for normal operation on kero.
This post was edited by 36F30 at 18:24:05 01/04/12.
Today's Featured Article - Storing Your Tractor - by Staff. If your tractor is going to be stored for any length of time, a few precautionary measures are helpful in preserving various parts, also in avoiding future difficulty. Store tractor under cover. If impossible to place tractor under cover, be sure to cover air stack and exhaust pipe. Drain radiator and engine block. To avoid gum content collections, drain both fuel tanks and carburetor. Leave radiator and fuel caps slightly loose to protect gaskets. Block tractor up to remove weight from tires and to keep tires from contact with moist floor. ... [Read Article]
