Re: Need help identifying a rod (pic)
Posted by Farmall-h on January 05, 2012 at 15:31:55 from (74.42.129.111):
In Reply to: Re: Need help identifying a rod (pic) posted by 36F30 on January 04, 2012 at 18:22:54:
They were an option on these tractors. My H was owned and sold to me by the original owner who told me that he was given the chance to put these on his H. He resides in brainerd Mn and said it worked wonders for keeping this tractor temprature at an optimal level during the winter months. My tractor was never a kerosene burner as there was no room for another small starting tank and the serial number end with X1 meaning STRICTLY GASOLINE. These shutters had more uses than what you may think.
-Cole
Today's Featured Article - Storing Your Tractor - by Staff. If your tractor is going to be stored for any length of time, a few precautionary measures are helpful in preserving various parts, also in avoiding future difficulty. Store tractor under cover. If impossible to place tractor under cover, be sure to cover air stack and exhaust pipe. Drain radiator and engine block. To avoid gum content collections, drain both fuel tanks and carburetor. Leave radiator and fuel caps slightly loose to protect gaskets. Block tractor up to remove weight from tires and to keep tires from contact with moist floor. ... [Read Article]
