Bet your not telling us the whole story are you??? Been sitting a long time?? You had some sort of other problem but have not told us??? Fill in the gaps and tell us all the info. If I had to guess I would say it sat a long time and you have rust in a cylinder or 2. Me I would fill trhe cylinders with ATF and let it sit a few days. Be sure to put the plugs back in to keep dirt etc out. Pull the plugs and try to spin it over. Ya it will shoot some ATF out but if it locks due to sitting a long time that should fix it
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
