Posted by Jake K on January 04, 2012 at 18:32:39 from (174.54.41.235):
I have a 1945 Farmall A Cultivision, and the engine turns over but then seizes.It seized once I got it lose by putting the hand crank on in the front. I tried it again and it seized again, and I got it lose by putting it in gear and rocking it. I don't want to invest a lot of money in it to get it to run.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
