I worked on a c one time that had sat in a barn for 10-15yrs cranked it over and as soon as it went pop like it was going to start, carbon in the cylinders fell and stoped the engine,I backed up the engine,pulled the plugs and blue out cylinders,put back together and ran good. Disconect the coil wire and use the hand crank you'll be able to feel and hear whats going on. be carefull, stumper
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
