Re: 1945 Farmall A Cultivision
Posted by gene bender on January 05, 2012 at 03:26:15 from (67.55.227.172):
In Reply to: 1945 Farmall A Cultivision posted by Jake K on January 04, 2012 at 18:32:39:
Are you sure the starter isnt hanging up because of bad connections or junk battery clean all connections first after you are sure the battery is good cause engines dont sieze up then turn over with crank. You also mite have a bad ring gear next time it does that remove the starter and look at the teeth on the ring gear and look over the Bendix real good take it to someone who knows a good one from a bad one.
