I had a machine shop in the 1960's -- 1990's. Zollner made most of the pistons on IHC engines. I remember the C 301 gas & LP as having a problem scuffing on the # 5 & 6 cyl's. Either IHC or Zollner had a service bulletin that stated increase # 5 to .005 & # 6 to .0055.?? I know we determined they diddn't have enough cam grind in the piston skirt. We bored & honed to their recommend specs, then put a Pefect Circle knurl on the skirt to bring it back to around .004. The knurl helped retain the oil on the skirt of the piston.Never had another engine score. I hope this helps. They only gave trouble doing the heavy field work. When you get your tractor running take a temp heat gun & see how much hotter the back cyl's run. Make sure you have a "A" plus radiator. Are any of your radiator shops using flow test equipment? I plow with my antique tractor & if you get the antifreeze mixture over 50-50 It doesnt cool as well.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble
... [Read Article]
Latest Ad:
[More Ads]
