Re: 1945 Farmall A Cultivision
Posted by stumper on January 05, 2012 at 23:10:10 from (24.180.126.224):
In Reply to: 1945 Farmall A Cultivision posted by Jake K on January 04, 2012 at 18:32:39:
something else is could be a stuck valve witch can be check by taking off the hood and the valve cover and watch. I would start by pulling the spark plugs and use compresed air and blow out anything that might be in there,to much oil in a cylinder will stop a motor in its tracks.
&with the plugs out see if it will turn over,and look and see with a little light if u can see anything, take care,stumper
