Re: Super-A brake pedal - wobbles on shaft
Posted by hendrik on September 06, 2000 at 13:04:53 from (62.100.4.107):
In Reply to: Super-A brake pedal - wobbles on shaft posted by Kendall on September 06, 2000 at 08:38:05:
I have exactly the same problem. The part that is worn most is not the shaft but the bearing hole it turns in. I'm going to try to swop the two bearing brackets. The one for the left brake pedal is worn less since the shaft of this left pedal is supported by TWO bearings, whereas the right one has only one. The left and right bearing brackets are identical.
Hope this helps, but haven't accomplished it yet. Hendrik
Post A Followup
: Re: Re: Super-A brake pedal - wobbles on shaft
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
